• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault Customization
    Active Contributor
    Programmatically create a bom
    149 Views, 2 Replies
    04-04-2012 02:53 AM
    Hi All
    Il release 2011 it was possible create a bom using UpdateItemBOMAssociations.
    But in release 2012 is not possible.In vault.chm i read that now,using this method,is possible to update existing links.
    Not possible adding links.In 2011 it was possible.
    Are there some workarounds?thanks
    Alessandro
    Please use plain text.
    Employee
    Daniel.Dulzo
    Re: Programmatically create a bom
    04-04-2012 10:09 AM in reply to: alexniccoli
    Hello Alessandro,
    This is actually a typo in the SDK documentation. The UpdateItemBOMAssociations method can be used for creating a BOM as well as updating BOM's. The Remarks section in the documentation should actually read, "Prior to calling this function, EditItem should be called to lock the parent Item for editing. After the BOM has been reordered, call a commit function, such as UpdateAndCommitItems, to finalize the changes."
    Regards
    Daniel Dulzo
    Software Engineer
    Active Contributor
    04-13-2012 02:04 AM in reply to: alexniccoli
    Sorry I have done an error.
    This method works well.As in past release.
