Nice. Some time back, I wrote a sample which auto-fires the JobProcessor.exe after the job is posted to job queue, so no need to wait till JobProcessor.exe to run up periodly to deal with your job. I copied the code below, in case it's useful for you:
Replace the QueuePublishJobCommandHandler function in QueuePublishJobCommandExtension.vb file with the following code:
Public Sub QueuePublishJobCommandHandler(s As Object, e As CommandItemEventArgs)
'Create your own job
For Each vaultObj As ISelection In e.Context.CurrentSelectionSet
Dim file As File = m_serviceManager.DocumentService.GetLatestFileByMasterId(vaultObj.Id)
Dim param1 As JobParam = New JobParam
param1.Name = "FileVersionId"
param1.Val = file.Id.ToString()
Dim fileNameParam As New JobParam()
fileNameParam.Name = "FileName"
fileNameParam.Val = vaultObj.Label
Dim mySyncJob As Job = _
m_serviceManager.JobService.AddJob("MyCompany.File.Publish", "property sync job", New JobParam() {param1, fileNameParam}, 1)
Next
' Try to run a new instance of Job Processor
Dim processes() As Process = System.Diagnostics.Process.GetProcessesByName("JobProcessor")
If processes.Count > 0 Then
Dim Pcs As Process
For Each Pcs In processes
Pcs.CloseMainWindow()
Next
End If
Try
Dim mypcs As New Process
mypcs.StartInfo.FileName = "JobProcessor.exe"
mypcs.Start()
Catch ex As Exception
End Try
End Sub
Next, replace the Execute function in FolderPublishJobHandler.vb file with the following code:
Public Function Execute(context As IJobProcessorServices, job As IJob) As JobOutcome Implements IJobHandler.Execute
Dim fileMasterId As Long = Convert.ToInt64(job.Params("FileVersionId"))
Dim fileName As String = job.Params("FileName")
Try
' Do something here, e.g. PrintFiles
' Close the JobProcessor.exe
Dim Pcs As Process
Next
End If
Return JobOutcome.Success
Catch er As Exception
Return JobOutcome.Failure
End Try
End Function
Barbara Han
Developer Technical Services
Autodesk Developer Network
