• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault Customization
    Active Contributor
    Is a message on failed login possible?
    139 Views, 3 Replies
    09-12-2012 07:15 AM
    Is it possible to get a message on a failed login, such as
    - license limit has been reached
    - Vault database not found
    - username and password not found
    Mike
    PS I am using the WebServiceManager in Vault Professional 2013.
    Please use plain text.
    Employee
    Re: Is a message on failed login possible?
    09-13-2012 05:03 AM in reply to: michael.collins2
    If something goes wrong with the login, you will get an exception when creating the WebServiceManager object.  Errors from the Vault server will have an error code.
    http://justonesandzeros.typepad.com/blog/2011/11/getting-the-restriction-codes.html
    If you want a human readable message, you will have to convert the error code to a human readable string.  You can provide you own messages or copy them from the SDK documentation.
    http://justonesandzeros.typepad.com/blog/2012/01/better-error-messages.html
    Doug Redmond
    Software Engineer
    Active Contributor
    09-13-2012 07:19 AM in reply to: Redmond.D
    So for login errors, am I on the right path with something like:
    try
        m_serviceManager =
        new WebServiceManager(newUserPasswordCredentials(
             server, vault, username, password, true));
    catch (Exception ex)
      string errorCode;
      List<string> restrictionCodes;
         GetErrorAndRestrictionCodesString(ex, out errorCode, out restrictionCodes);
    Employee
    09-14-2012 05:26 AM in reply to: michael.collins2
    Yes, that should work.  You can test it out pretty easliy.  Just log in with a bad password.
    Doug Redmond
    Software Engineer
