• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault Customization
    Active Contributor
    gary.belisle
    Accepted Solution
    How to customize "autodeskdmhelp:ID_Landing_Page.htm"
    233 Views, 13 Replies
    04-25-2012 07:46 AM
    I would like to customize the default page in Vault Pro 2012. This looks like a good spot for a company wiki style page where I could point to standards and work instructions. I clicked on the "Customize This Page" link and received an error "The webpage cannot be displayed".
    Where can I edit this?
    If there is something better in the 2013 release, I can hold out for whatever that is when we do the upgrade.
    Please use plain text.
    Employee
    Daniel.Dulzo
    Re: How to customize "autodeskdmhelp:ID_Landing_Page.htm"
    04-25-2012 08:17 AM in reply to: gary.belisle
    Hello Gary,
    I believe the link you're talking about tries to open a browser to this help page describing how to customize the landing page. http://wikihelp.autodesk.com/Vault/enu/Help/Help/0097-Administ97/0127-Client_A127/0187-Customiz187. Hopefully this has the information you're looking for.
    Daniel Dulzo
    Software Engineer
    Autodesk, Inc.
    Active Contributor
    gary.belisle
    04-25-2012 09:15 AM in reply to: Daniel.Dulzo
    Yes, thank you! That is what I needed.
    In a replicated environment, can each server have a different index.htm?
    Active Contributor
    gary.belisle
    04-25-2012 01:29 PM in reply to: gary.belisle
    I've performed some basic modifications, and cleared the IE history, but the vault client still loads the original index. How do I get this to refresh?
    Moderator
    MiWaNiZa
    05-10-2012 07:24 AM in reply to: gary.belisle
    I'm running Vault at Windows Server 2008 R2, and landing page is placed at:
    "C:\Program Files (x86)\Autodesk\ADMS Professional 2012\Server\Web\Services\VaultHTML\index.html"
    The code is:
    <HEAD>
    <meta HTTP-EQUIV="REFRESH" content="0; url=http://srv1/pwa/tasks.aspx">
    </HEAD>
     So try to correct file on server using that path, and try use redirection, instead editing landing page file.
    Good luck!
    ________________________________________________
    Сообщество пользователей Autodesk
    Блог
    Читаем правила форума
    Distinguished Contributor uma
    04-22-2013 01:32 AM in reply to: gary.belisle
    Have you achieved the desired?
    I've changed landing page url in C:\Program Files\Autodesk\ADMS Professional 2013\Server\Web\Services\VaultHTML\index.html:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
    <head>
    <meta http-equiv="Content-type" content="text/html; charset=utf-8" />
    <title>Autodesk Vault</title>
    <script type="">
        function doConnectFunction() {
            //I'm fired if I'm connected to the internet
            redirURL = "http://go.tavrida.com/";
            self.setTimeout("self.location.href = redirURL;", 0000);
        function doNoConnectFunction() {
            //I'm fired if I'm not connected to the internet
            redirURL = "#";
    </script>
    <script type="">
        var i = new Image();
        i.onload = doConnectFunction;
        i.onerror = doNoConnectFunction;
        i.src='http://www.autodesk.com/images/logo.gif?d=' + escape(Date());
        //escape(Date()) necessary to override possibility of image coming from cache
    </script>
    </html>
     and also has original page in client.
    What I'm doing wrong?
    Moderator
    MiWaNiZa
    04-22-2013 02:24 AM in reply to: uma
    Try to open index.html right from it's location.
    If it's working as conceived, try to restart IIS: launch command prompt and type "iisreset".
    Блог
    04-22-2013 02:31 AM in reply to: MiWaNiZa
    "iisreset" havn't helped either...
    Moderator
    MiWaNiZa
    04-22-2013 02:41 AM in reply to: uma
    Backup index.html and replace it with next code:
    <HEAD>
    <meta HTTP-EQUIV="REFRESH" content="0; url=http://google.com">
    </HEAD>
     Is it works fine?
    Блог
    04-22-2013 02:45 AM in reply to: MiWaNiZa
    Index with google opens itself correctly but even after iisreset the original page shows inside client.
    (btw my index posted above doesn't open even itself).
