• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault Customization
    Valued Contributor kbo
    Valued Contributor
    kbo
    Accepted Solution
    Here is a working Windows login to vault but how do i ensure a right logout
    388 Views, 5 Replies
    01-23-2012 11:54 AM
    I played around with the listfiles example in the Vault sdk and struggled, like a lot of others i think. With getting the windows login to work. i made it at an inventor addin and here is what worked for me. but how do i ensure a proper logout? any help appreciated
    regards.
    kent boettger
     Private Const HOST As String = "srv-pdm" '"localhost"
        Private Sub button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles button1.Click
            'RunCommandNormalLogin(HOST)
            RunCommandWinLogin(HOST)
        End Sub
        Public Sub RunCommandWinLogin(ByVal serverName As String)
            'Login with Windows User login
            Dim winAuthSvc As WinAuthService = New WinAuthService()
            winAuthSvc.Url = "http://" + serverName + "/AutodeskDM/Services/WinAuth/WinAuthService.asmx"
            winAuthSvc.UseDefaultCredentials = True
            winAuthSvc.SecurityHeaderValue = New WinAuthSvc.SecurityHeader()
            winAuthSvc.SignIn("Vault")
            Dim docSrv As DocumentService = New DocumentService()
            docSrv.SecurityHeaderValue = New Autodesk.Connectivity.WebServices.DocumentSvc.SecurityHeader()
            docSrv.SecurityHeaderValue.UserId = WinAuthSvc.SecurityHeaderValue.UserId
            docSrv.SecurityHeaderValue.Ticket = WinAuthSvc.SecurityHeaderValue.Ticket
            docSrv.Url = "http://" + serverName + "/AutodeskDM/Services/DocumentService.asmx"
            Dim login As WinAuthCredentials = New WinAuthCredentials(serverName, "Vault")
            Using serviceManager As New WebServiceManager(login)
                Try
                    Dim root As Folder = docSrv.GetFolderRoot()
                    Me.m_listBox.Items.Clear()
                    PrintFilesInFolder(root, docSrv)
                Catch ex As Exception
                    MessageBox.Show(ex.ToString(), "Error")
                End Try
            End Using
        End Sub
    Please use plain text.
    Employee
    Re: Here is a working Windows login to vault but how do i ensure a right logout
    01-27-2012 05:09 AM in reply to: kbo
    The WebServiceManager will log out for you when the USING block exists.  This article explains things more.
    I apologize.  The VB version of VaultList could have been written better.  In fact, you can remove about half the code in your RunCommandWinLogin.  Everything before "Dim login as WinAuthCredentials" can be removed.
    For the next SDK release, we cleaned it up a bit to look like this...
        Private Sub button1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles button1.Click
            ListAllFiles()
        End Sub
        ''' <summary>
        ''' This function lists all the files in the Vault and displays them in the form's ListBox.
        ''' </summary>
        Public Sub ListAllFiles()
            ' Set up the login credentials for Vault.
            ' For demonstration purposes, the information is hard-coded.
            Dim login As New UserPasswordCredentials("localhost", "Vault", "Administrator", "", _
                True)  ' log in as read-only, which doesn't consume a license
            ' Create the WebServiceManager which can be used for all Vault Server calls.
            ' Putting the manager in a using block insures that it logs out when we are done.
                Try
                    ' Start at the root Folder.
                    Dim root As Folder = serviceManager.DocumentService.GetFolderRoot()
                    ' Call a function which prints all files in a Folder and sub-Folders.
                    PrintFilesInFolder(root, serviceManager)
                    Return
                End Try
            End Using
        End Sub
    Doug Redmond
    Software Engineer
    Autodesk, Inc.
    http://justonesandzeros.typepad.com/
    Active Member
    05-29-2012 11:55 AM in reply to: Redmond.D
    Hi Doug,
    I'm trying to search through these forums for problems similar to mine and found this one.  Do the changes you made to Kent's original code still use the Windows login credentials?  What about the Windows Authorization Service?  Does it not get used anymore?  You commented that you hard-coded for demonstration purposes, but now I'm really confused.  Does your solution maintain the original login intent?
    Larry Daubenspeck
    Larry Daubenspeck
    Software Programmer
    Draper, Inc.
    Employee
    Daniel.Dulzo
    05-30-2012 07:52 AM in reply to: larry.daubenspeck
    Hi Larry,
    Doug's code above doesn't use windows authentication, but demonstrates how to use the WebServiceManager to manage logging in and out of a Vault for you. The WinAuthService is still used, but if you use the WebServiceManager, it handles everything for you. You can give the WebServiceManager different types of credentials in its constructor if you would to authenticate in different ways. If you're trying to log in to a vault using windows authentication, you should construct the WebServiceManager using the WinAuthCredentials class. An example of its usage can be seen below:
    using(WebServiceManager wsManager = new WebServiceManager(new WinAuthCredentials("localhost", "Vault"))
         // use the wsManager here to make sever calls to vault
    For more information, I recommend consulting the article that Doug points out in his post above.
    Daniel Dulzo
    Software Engineer
    Autodesk, Inc.
    Distinguished Contributor
    08-15-2012 11:54 PM in reply to: Daniel.Dulzo
    Maybe a bit offtopic, but what about PowerShell? The hardcoded variant is:
    Add-Type -Path "C:\Program Files (x86)\Autodesk\Autodesk Vault 2012 SDK\bin\Autodesk.Connectivity.WebServicesTools.dll" $cred = New-Object Autodesk.Connectivity.WebServicesTools.UserPasswordCredentials ("<TODOservername>","<TODOdatabase>","<TODOaccount>","<TODOpassword>",$true)
    $webSvc = New-Object Autodesk.Connectivity.WebServicesTools.WebServiceManager ($cred)
    Could you plese help to modfy it to WinAuth variant?
    MaxU77,
    AI2011 Certified Associate
    (Soft: PDSU2012, VP2012&VP2013)
    Employee
    08-16-2012 06:38 AM in reply to: MaxU77
    If you can't use a USING block, you can call Dispose() when you are done with the WebServiceManager.  The Dispose will take care of the logout.
    Example:  $webSvc.Dispose()
    Doug Redmond
    Software Engineer
    Autodesk, Inc.
