Get Id of Release State
blokmech
blokmech
Hi all,
I'm looking for the "Released State" id for a particular lifecycle definition, but I'm lost.
Who can point me to the right direction?
The code I use is:
Dim LfCycDefs = serviceManager.DocumentServiceExtensions.GetAllLifeCycleDefinitions
Dim ReleaseProcessID = LfCycDefs.FirstOrDefault(Function(states) states.SysName = "My Release Process")
Dim ReleaseId As Long
  For Each StateID In ReleaseProcessID.StateArray
    If StateID.DispName = "Released" Then
   ReleaseId = StateID.Id
Next
Redmond.D
It looks like you are confusing system name and display name.
To find your lifecycle definition you need to run the following comparison:
      states.DispName = "My Release Process"
Doug Redmond
Software Engineer
Autodesk, Inc.
blokmech
Doug,
You are correct, but I think I'm very close to the solution what i want, but still it's not working. It fails on the line starting with " docsvcExt.UpdateFileLifeCycleStates"
I also changed the method of getting the Id(I know it is not the most fine solution...):
Dim LifeCycleId As Long
  For Each LfCycle In LfCycDefs
    If LfCycle.DispName = "My Release Process" Then
    LifeCycleId = LfCycle.Id
  Next
'Get LifeCylceStateID of "Released"
Dim FileStates = ServiceManager.DocumentServiceExtensions.GetLatestRevisionLifeCycleStatesByDefinitionId(LifeCycleId)
Dim ReleaseId() As Long
  For Each StateID In FileStates
    ReleaseId = New Long() {StateID.Id}
  Next
Dim docsvcExt As New Autodesk.Connectivity.WebServices.DocumentServiceExtensions
Dim PDFs As Autodesk.Connectivity.WebServices.File() = serviceManager.DocumentService.GetLatestFilesByFolderId(FolderPDFId1, False)
  For Each pdf As Autodesk.Connectivity.WebServices.File In PDFs
    If pdf.FileLfCyc.LfCycStateName = "Work in Progress" Then
    Dim pdfmasterid() As Long = New Long() {pdf.MasterId}
   docsvcExt.UpdateFileLifeCycleStates(New Long() {pdfmasterid(0)}, New Long() {ReleaseId(0)}, "Released for Purchase Department")
  Next
blokmech
Anyone?
Redmond.D
Are there any more details you can give on the failure, such as the error code?
Here is some code for extracting the error and restriction codes.
Doug Redmond
Software Engineer
Autodesk, Inc.
