• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault Customization
    Active Contributor
    Disabling CAD Client Functions
    177 Views, 1 Replies
    09-16-2012 02:54 PM
    Hi all.  Our Vault is heavily customised, I have a load of automated triggers from third party developers that kick in on file and item lifecycle state change.  The problem I have is all the add-ins are Vault Client based, they don't all function 100% if a file is changed state from within the CAD client.
    Rather than ask the developers to extend their code into the CAD clients, I'd prefer to have the option to completely remove the ability to change lifecycle states from within CAD clients.  Is this possible? If I need to do a registry hack I'll do it!
    Cheers.
    Engineering Data Manager - Soil Machine Dynamics.
    Autodesk Inventor Certified Professional
    Please use plain text.
    Employee
    Re: Disabling CAD Client Functions
    09-18-2012 04:40 AM in reply to: neil.cross
    This can be done with another Vault API trigger.  Hook into the GetRestrictions event on a file lifecycle change.  In the GetRestrictions code, check the process name.  If you are running in a CAD application, you can add a restriction and block the operation.
    Doug Redmond
    Software Engineer
    http://justonesandzeros.typepad.com/
