Thank You Doug,
That did the trick.
Here is the section of code that I modified from the original VaultFileBrowser SDK code in case someone else needs it.
Note that this will cause the deleation of files without user intervention based on the search criteria.
I used the Advanced Find to filter the files with Category contains Name and File contains .DWFX
This allowed me to delete a large number of specific .DWFX files.
Dim fileList As List(Of FileFolder) = New List(Of FileFolder)()
Dim bookmark As String = String.Empty
Dim status As SrchStatus = Nothing
While (status Is Nothing OrElse fileList.Count < status.TotalHits)
Dim files As FileFolder() = m_docSvc.FindFileFoldersBySearchConditions(conditions, Nothing, Nothing, True, _
True, bookmark, status)
If (Not files Is Nothing) Then
fileList.AddRange(files)
End If
Label3.Text = fileList.Count.ToString & " of " & status.TotalHits.ToString
Me.Refresh()
End While
If (fileList.Count > 0) Then
'iterate through found files and display them in the search results list box then delete it
For Each file As FileFolder In fileList
'create the list item that will wrap the File
Dim fileItem As ListBoxFileItem = New ListBoxFileItem(file.File)
m_searchResultsListBox.Items.Add(fileItem)
' This next line will delete the File without warning
m_docSvc.DeleteFileFromFolderUnconditional(file.File.MasterId, file.Folder.Id)
Next file
