Complex Numbering Generator
tadegen
tadegen
I need to implement my own number generator because its complexity exceeds the possibilities of the built-in file numbering generator. The implementation on the cad side should be easy, just don't use the built-in mechanism but execute my own plugins. But how can the internal number generator be replaced by my own code within the rename file function? Is this possible?
Tobias
Redmond.D
You can't replace Vault's number generator.  You would need to write your own rename command.
Doug Redmond
Software Engineer
Autodesk, Inc.
