AddChangeOrder Example?
Does anybody have a working example of creating a change order via the API in 2013? (.NET)
I've been playing around but keep getting Soap Exception 106.
Thanks in advance,
Tom
minkd
The 106 error indicates that you are trying to call a method prior to signing-in as a user.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
Hmm, well I thought I was logging in correctly but perhaps not.
Here's what I've got so far:
        Dim login As New UserPasswordCredentials("ellisws1", "Routing", "Administrator", "")
        Using serviceManager As New WebServiceManager(login)
            Try
                Dim myeco As ChangeOrderService
                myeco = New ChangeOrderService
                ' get the default routing
                Dim workflow As Workflow = myeco.GetDefaultWorkflow()
                Dim routings As Routing() = myeco.GetRoutingsByWorkflowId(workflow.Id)
                Dim defaultRouting As Routing = routings.FirstOrDefault(Function(n) n.IsDflt)
                If defaultRouting Is Nothing Then
                    Throw New Exception("No default routing")
                ' get the next number in the default sequence
                Dim numberingSchemes As ChangeOrderNumSchm() = _
                    myeco.GetNumberingSchemesByType(NumSchmType.ApplicationDefault)
                Dim defaultNumberingScheme As ChangeOrderNumSchm = numberingSchemes.FirstOrDefault()
                If defaultNumberingScheme Is Nothing Then
                    Throw New Exception("No default numbering scheme")
                Dim coNumber As String = myeco.GetChangeOrderNumberBySchemeId(defaultNumberingScheme.Id)
                Dim newCo As ChangeOrder = myeco.AddChangeOrder(defaultRouting.Id, coNumber, "test", "testing desc", DateTime.Now.AddMonths(1), Nothing, Nothing, Nothing, Nothing, Nothing, Nothing, Nothing)
            Catch ex As Exception
                MessageBox.Show(ex.Message, "Error creating ECO")
                Return
            End Try
        End Using
The 106 error comes from the GetDefaultWorkflow function.
Any advice?
Thanks.
Redmond.D
Don't new-up any of the Service objects.  The WebServiceManager takes care of all that.
Replace the line
with
     myeco = serviceManager.ChangeOrderService
That should get your farther in your code.
Doug Redmond
Software Engineer
Autodesk, Inc.
Ahhh. That makes sense.
Its working now.
Thanks!
