• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Utility Design
    Line Labeling in AUD
    1486 Views, 4 Replies
    11-03-2009 09:51 AM
    I am having a problem with the "Label Conductor" function: I mapped our entire system with AUD and as the file has gotten larger the time to label a line has gotten longer.
    I am about 80% complete, but labeling a line takes more than a minute now. Any ideas on how to shorten this time would be appreciated. Sitting here looking at my screen for more than a minute for each line just doesn't seem right to me.
    Please use plain text.
    Re: Line Labeling in AUD
    11-04-2009 09:56 AM in reply to: heberpower
    This go back to AUD 06, but you can try changing your "Join labeled lines (Auto/Select/none)". Change it from Auto to Select. At the command prompt you will need to type "UDSSETCFG" (you may need the password). In the "Configuration" dialog box select "hardware, extracting, autocad and yes/no parameters". Then select "Join labeled lines" and change it to "S". now you will have to select each conduit for your cost. but now it will not search all the conduit.
    I will attach my quick note.
    I hope this help you
    Corn
    11-04-2009 10:46 AM in reply to: heberpower
    Hey thanks! It works perfectly now. How do you find all of the obscure commands?
    Thanks again
    Troy K.
    11-04-2009 11:00 AM in reply to: heberpower
    I'm the number two guy and the number one guy is PUSHING me up to number one and half. LOL
    Grad I can help
    Corn
    11-05-2009 08:18 AM in reply to: heberpower
    Hey corn, any ideas an this one. UDSDWGSTAT results in this:
    The scale of this drawing is 40 and model number 0.
    Any idea on how to change to 40 to a 1?
