• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Utility Design
    AUD Line Lengths
    1640 Views, 5 Replies
    11-04-2009 09:25 AM
    Me again, hey does any body know why my line lengths are wrong in AUD? If I list a line using the "LIST" command the length is correct, when I use the "AUDINFO" command the lengths are incorrect. For expample I just listed an underground primary line that measures 134.78 Meters using the standard "LIST" command. When I use AUDINFO I get a measurement of 5586. Any help would be great!
    Thanks in advance.
    Please use plain text.
    Re: AUD Line Lengths
    11-04-2009 02:29 PM in reply to: heberpower
    After some more digging I have discovered that the measurements are off by exactly 40....Please help.
    11-05-2009 08:15 AM in reply to: heberpower
    I have figured out more of my problem but not all...when I invoke the UDSDWGSTAT command I get this result:
    The scale of this drawing is 40 and model number 0.
    I need to know the command to change the 40 to a 1...Anyone?
    Employee
    11-06-2009 09:56 AM in reply to: heberpower
    AUDINFO calculates additional wire length based on the connected structure, and the value set in configuration.
    Make a note of the structure connected to the wire, then look in the configuration:
    AUDCONFIG > Facilities > Structure
    On the block name, "Additional Wire" will likely be 40.
    Jeff Paquette
    11-06-2009 01:39 PM in reply to: heberpower
    Well Heberpower,
    Did this help?
    Thanks Corn
    11-09-2009 07:22 AM in reply to: heberpower
    I figured ot out...Somehow SETVAR "useri1" was set to 40, changed it to 1 and everything is good now.
    Thanks for all your help!
    Heber Power
