• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Topobase
    Active Member
    topobase admin locked
    50 Views, 2 Replies
    03-11-2008 01:47 AM
    when i try to start topobase admin then i get the error message that " your account is locked".
    how to solve this problem
    Please use plain text.
    Member
    Re: topobase admin locked
    03-13-2008 06:11 AM in reply to: ramandeep_TCS
    i had the same problem ... and that's how i solved it - > http://discussion.autodesk.com/thread.jspa?threadID=649445
    03-26-2008 11:00 AM in reply to: ramandeep_TCS
    Here is a little tip if you are using Topobase in a test environment and you are using the sample data that comes with the product or if your account is getting locked frequently due to incorrect logins.
    Here is the workaround:
    Log into SQLPlus as your system user and run the following
    CREATE PROFILE DEFAULT_TOPOPASE
    LIMIT FAILED_LOGIN_ATTEMPTS UNLIMITED;
    ALTER USER TBSYS PROFILE DEFAULT_TOPOBASE;
