• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Topobase
    Member
    Topobase: setting user access permissions at the features level
    729 Views, 4 Replies
    01-08-2010 05:45 AM
    Is there someone who has some experience on setting the user group access permissions at the feature classes level (select; insert; update; delete) ?
    Please use plain text.
    Re: Topobase: setting user access permissions at the features level
    02-16-2010 06:45 AM in reply to: DiaconuI
    If you use TB 2010 you can do this with TB Admin (Setup >> Security Administarator)
    tmgovind
    07-03-2010 11:23 AM in reply to: Shatohin
    Hi
    I am new to Topobase. I have installed TB client 2011 64 bit version on Win 7.
    I need clarification on how rights (Create,Delete, Update), Users and roles are related in TB.
    I  logged in as TBSYS in TB administrator and created a workspace and a Water document using the in built template. Later i created a user group CWEDITORS i.e CleanWater Editors and assigned the workspace that i created earlier to this usergroup.
    Then i created a user, say U1, and assigned it to CWEDITORS. In Security Administrator i created a ROLE for which a password was also assigned and using the GUI i assigned the CRUD previliges to this role.
    1) What i actually wanted was to assign the roles (created using TB Security administrator) to either the user groups or users.(Is this possible) ? It is not clear how to do this as the roles are defined at oracle level and my understanding is that the users are created at application level (i.e users like TOPOBASE, U1)
    2) What is a guest document? Can someone explain more clearly?
    Regards
    Govind
    tmgovind
    07-07-2010 11:54 PM in reply to: Shatohin
    Hi
    Thanks for ur response. As i had mentioned earlier i am using 2011
    In the Security Administrator i didnt see any provision to Assign the roles to a Group or user.
    Am i missing something?
    Regards
    Govind
    07-20-2010 12:52 AM in reply to: tmgovind
    Hi Govind,
    You should create a new workspace and add a guest document there. After that you will be able to configure user rights at workspace level.
    BR
    Alexander Shatohin
