Autodesk Topobase
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Topobase Web and multiple servers
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
131 Views, 3 Replies
01-16-2008 05:30 AM
Dear Discussion Group,
I'd like to ask if anyone knows, if Topobase Web is capable of using multiple servers (like MapGuide 6.5 was), so if one server is busy, the requests are passed to another one, set up for the same task.
Thanks, regards,
Gabor Grosz
Thanks, regards,
Gabor Grosz
*Charly Lebrun
Re: Topobase Web and multiple servers
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-18-2008 02:17 AM in reply to:
gabag
> Thanks, regards,
> Gabor Grosz
Yes it can, but you must have one fixed main server. If load-balancing
is your goal, then check with Autodesk.
Charly
> Thanks, regards,
> Gabor Grosz
Charly
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-21-2008 10:18 AM in reply to:
gabag
Thank you very much, seems we are going to need it
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-26-2008 01:13 PM in reply to:
gabag
With Topobase Web 2008, it is possible to use the pragmatic load balancing feature (similar to 6.5).
the difference is that once a session is established, you are linked to that server for the session i.e. if you log into Topobase Web, you will be working with the same server till you log out. The next user however might be redirected to the available server if the first one is in use.
Here is how you would set it up.
The default web tier configuration file, webconfig.ini contains the following settings (comments have been removed for conciseness):
[AdministrativeConnectionProperties]
Port = 2810
[ClientConnectionProperties]
Port = 2811
[SiteConnectionProperties]
IpAddress = 127.0.0.1
Port = 2812
To set up the web tier to access two site servers, with ip addresses 111.111.111.111 and 111.111.111.222 using the standard ports, only the IpAddress setting needs to be modified:
Port = 2810
Port = 2811
IpAddress = 111.111.111.111,111.111.111.222
Port = 2812
It is also possible to use different port settings for each server. So if server 111.111.111.111 uses the standard ports, and 111.111.111.222 uses 2820, 2821 and 2822, the settings should look like this:
Port = 2810,2820
Port = 2811,2821
Port = 2812,2822
Port = 2810
Port = 2811
Port = 2812
Port = 2810
Port = 2811
Port = 2812
Port = 2810,2820
Port = 2811,2821
Port = 2812,2822
