• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Topobase
    Active Member
    Topobase Web Procedure Revision problem
    171 Views, 2 Replies
    12-02-2009 02:40 PM
    I'm trying to connect to Topobase Web after installing the Topobase Administrator Service Pack 1. I'm getting the following error
    "The serverside stored procedures (7.00.72) are newer than the installed Topobase version (7.00.41). Please update the installed Topobase software."
    I've updated the Topobase Administrator and Topobase Server Administrator shows that everything appears to be current. What component needs to be updated?
    Kern
    Please use plain text.
    Member
    Re: Topobase Web Procedure Revision problem
    12-03-2009 12:16 AM in reply to: KernBlackburn
    Hi, you need apply Autodesk Topobase Web 2009 Update 1
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14075703&linkID=9242779
    Active Member
    12-03-2009 07:15 AM in reply to: KernBlackburn
    Thanks! I was having trouble finding the link to download the patch.
    K
