• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Topobase
    Member
    TBWEB LOGIN ERROR
    114 Views, 2 Replies
    07-05-2009 10:01 PM
    I'm trying to login TBWEB through (http://localhost/MapGuide2010/TBWeb/Login.aspx)..
    and getting an error saying 'Failed to check license for Autodesk Topobase Web, it cannot continue'
    I have obtained the license for web but don't know where exactly to update...
    Tried to update TBWEB license as I did for topobase client license updation as given in 'Topabase installation and configuration' pdf
    but its not working this way..
    Thanks in advance
    Please use plain text.
    Active Member
    Re: TBWEB LOGIN ERROR
    12-07-2009 10:24 AM in reply to: aarathik
    Hi, i'm running into the same issue. Were you able to figure out this issue?
    Active Member
    12-07-2009 10:33 AM in reply to: aarathik
    I run the LMTOOLS Utility, go to "Start/Stop/Reread" tab, click on "Stop Server" and "Start Server" and it works for my case. Edited by: HyVong on Dec 7, 2009 6:33 PM
