• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Topobase
    Active Member
    Spatial Report Design TOPOBASE
    949 Views, 1 Replies
    04-04-2011 05:09 AM
    Hy!
    I'am new to topobase administrator and i'm trying to create a spatial selection report.
    i'm using gas data model and i want to select all pipes that have an atribute smaller than a certain value. I want to print all the features but each on a different page witn zoom extends and and havind some atributs listed at the bottom of the page.
    do you have a better idea rather than using Topobase spatial selection reports?
    Thanks in advance.
    Please use plain text.
    Active Contributor
    Re: Spatial Report Design TOPOBASE
    07-14-2011 10:45 AM in reply to: amalia_stan
    You may already have your answer but a spatial report is an easy way to get your answers.  I assume you will be choosing small portions of your system not the complete system since you are using spatial.  Make sure you use style: Formular to get each on a separate page.  Module Name must be set to Topobase.SpatialExportTool and ParameterID=1 and SpatialMask = anyinteract.
    I hope this helps.
