• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Topobase
    New Member
    SDO Geometry
    126 Views, 1 Replies
    03-14-2008 03:00 AM
    We have problems with importing SDO geometry from spatial geometry data in oracle 10 to Topobase 2008. With the import we got the message, it doesn't matter if the objects where lines or points:
    ERR> Update WA_LINE set GEOM =mdsys.sdo_geometry(3002,null,null,mdsys.sdo_elem_info_array(1,2,1),mdsys.sdo_ordinate_array(3485804.528,5542216.597,0,3485803.779,5542216.018,0,3485801.333,5542197.221,0)) where FID = ' 9940099'
    ^ERROR
    SQL execution error, ORA-29877: ORA-29877: Routine ODCIINDEXUPDATE nicht erfolgreich ausgeführt
    ORA-13364: Ebenendimensionalität stimmt nicht mit Geometrie-Dimensionen überein
    ORA-06512: in "MDSYS.SDO_INDEX_METHOD_10I", Zeile 243
    coordinate system are the same of both database. TB dictionary x + y is set to 10 000 000. The SDO meta data of both oracle dumps are also the same.
    Anyone here an idea?
    best regards G+B
    Please use plain text.
    Re: SDO Geometry
    03-26-2008 10:56 AM in reply to: LevonVardanyan
    Hi there
    Could it be that the SDO geometry that you are trying to insert is 3D (i.e. has a Z value) and the default index in Topobase 2008 is for 2D geometry data?
    Update WA_LINE set GEOM =mdsys.sdo_geometry(2002,null,null,mdsys.sdo_elem_info_array(1,2,1),mdsys.sdo_o rdinate_array(3485804.528,5542216.597,3485803.779,5542216.018,3485801.333,55 42197.221)) where FID = ' 9940099'
    Try this instead to see if it makes a difference?
    Regards
    Arnab
