Autodesk Topobase
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Generate Graphics
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
59 Views, 1 Replies
01-23-2007 07:10 PM
So I think I've got the Water application running. I can see all sorts of information in the forms but I can not generate graphics.
Could someone be so kind as to tell me how I can get some coordinate information to use with a window when generating graphics?
Thanks in advance,
Brek
Thanks in advance,
Brek
Re: Generate Graphics
Options
- Highlight
- Email to a Friend
01-26-2007 12:35 PM in reply to:
spatialnetbrek
Are you using your own data set or the one that comes with the application?
If you are using the one that comes with the application, you will find that there is a bunch of .layer files in the templates folder. You can drag them on to the Map display manager and save the file as a DWT template. (make sure that your drawing units are meters/feet or unitless)
Then assign the template to the Workspace using the Administrator.
The Generate Graphics loads the assigned DWT and then loads each layer within it.
Hope this helps
Arnab
Hope this helps
Arnab
