• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Topobase
    Active Member
    Exporting SDF into Topobase
    216 Views, 6 Replies
    10-12-2009 03:42 AM
    l am accessing Topobase for my company,
    l have problem exporting SDF into Oracle
    Please use plain text.
    Active Member
    Re: Exporting SDF into Topobase
    10-12-2009 06:28 AM in reply to: Ahmed.Giwa
    Can you provide a few more details about your situation? What kind of problem are you seeing? Are you getting an error message? Is the message from Oracle? What is the message number?
    Kern
    Active Member
    10-12-2009 08:13 AM in reply to: Ahmed.Giwa
    Hello Kern,
    Thank you for the prompt response, I have issues linking my spatial data with Topobase. Also when I tried to digitise on the data in Map it gives an error about different coordinate, going back to the Administrator it will not allow me to edit the document spatial unit.
    Is it possible to import SDF data into Topobase Client.
    Many thanks,
    Medoline
    Active Member
    10-12-2009 03:09 PM in reply to: Ahmed.Giwa
    Yes it is possible to import SDF data into the Topobase Client. You can set up a data connection to an SDF file through the display manager.
    Active Member
    10-13-2009 12:47 AM in reply to: Ahmed.Giwa
    Hi Kern,
    l have displayed the SDF using Display Manager, cheers
    Is it possible to insert the different features from the SDF into the data model?
    The features have already been created using AutoCAD and Map 3D
    Thank you.
    Active Member
    10-13-2009 07:38 AM in reply to: Ahmed.Giwa
    Yes you can with provisions.
    The feature classes should already exist in the Topobase workspace you are connected to and the coordinate systems are identical between the geometries coming in from the SDF file an the Topobase document.
    Highlight the geometries in the drawing. Right-Click the feature class from the Topobase Explorer and "Create New Feature From Geometry"
    K
    Active Member
    10-14-2009 12:19 AM in reply to: Ahmed.Giwa
    Dear Kern,
    It worked perfectly, thank you so much for your help Kern.
