Autodesk Topobase
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Delete a Label
- Highlight
- Email to a Friend
Re: Delete a Label
- Highlight
- Email to a Friend
Hello deetersmith,
if I want to delete a label, I look for the id of the parent object, open the form of the label, search the parent-fid, and then delete the record of the label. After that the label doesn't exist any more. What I don't know how to do is to grip a label in the drawing editor. It always seems the label is not selectable.
Thomas
Re: Delete a Label
- Highlight
- Email to a Friend
If you have Job enabled, on you must open a job. Next on the Home Ribbon, select the Edit Geometry button. When it is highlighted you can edit or delete features in the display such as labels. Select the label(s) you wish to delete with a left mouse click. This will turn the grips on for the features you select. Then click on your delete key on the key board or enter E as a command to erase them. Topobase will respond with a form asking if you are sure you want to delete. Answering yes will delete them.
Text can be displayed through the styling of a feature. You would need to alter the style so the text does not show. These are not labels and are edited in the display style. You could create different display models with and without the feature text.
