• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Survey Products
    Active Contributor
    quickcalc - convert DD to DMS
    1753 Views, 2 Replies
    05-04-2010 10:11 AM
    Hello Autodesk Surveyors,
    I have a closed traverse and want to do the following:
    1. convert between Degrees Minutes Seconds (DMS) to Decimal Degrees (DD)
    2. add several angles using DMS format
    I'm unable to see how to do this using the QUICKCALC command within AutoCAD. This seems very basic to me so I think I'm missing what command to use.
    Thanks for your help,
    Jeff Jensen
    Please use plain text.
    *Expert Elite*
    AllenJessup
    Re: quickcalc - convert DD to DMS
    05-04-2010 10:18 AM in reply to: jeffjensen
    Yes. It's very basic but I don't think you can do that in QuickCalc. I usually use an external calculator like Excalibur 32 and pass numbers back and forth using Copy/Paste.
    Allen
    Member
    JTJSBJB
    11-28-2010 02:40 AM in reply to: jeffjensen
    Hi Jeff,
    Maybe you can create small LISP to convert from DD to DMS and vice versa.
    TQ.
