• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Survey Products
    *TL
    description key file
    25 Views, 2 Replies
    05-13-2004 07:24 AM
    Hi, I'm trying to get a description key to match CC*, but not CCB*. I thought using CC[~B]* would do it but it doesn't. Even if I can't get it to work as I'd like, shouldn't CC[~B]* match any code that begins with a CC as long as the second C isn't followed by a B? (? is punctuation) Thanks.
    Please use plain text.
    Member
    Re: description key file
    06-03-2004 02:06 PM in reply to: *TL
    Go to [Point Settings..] then click on the {Descriptor Keys] tab Switch the search order to descending order
    *TL
    06-04-2004 06:08 AM in reply to: *TL
    nickmjr wrote: > Go to [Point Settings..] then click on the {Descriptor Keys] tab Switch the search order to descending order Thanks very much.
