• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Survey Products
    Distinguished Contributor
    bearing
    555 Views, 1 Replies
    01-12-2010 07:20 AM
    How do I find the bearing for a line with the following information?
    First point location=N26 degrees 15' 4", E56 degrees 26' 5"
    second point=N56 degrees 24' 13", E32 degrees 15' 06"
    Help please
    thanks
    Please use plain text.
    Active Contributor
    Re: bearing
    01-20-2010 07:41 AM in reply to: drafter1411
    type 'units', set your angle type to surveyors units. click ok. if the line is drawn you just select it, right click, select properites and the length and bearing will be listed towards the bottom of the properties dialogue box. you can also select the analyze tab on your ribbon, you can select the inquiry tool button or the line and arc information button and this will give you the bearing distance of the line.
