• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Survey Products
    Valued Contributor
    Survey Package
    2349 Views, 5 Replies
    03-29-2010 09:26 AM
    Does Civil 3D have everything in it for a Surveying Package? We are currently using a 3rd party software add-on (Carlson) but I'd like to eliminate the extra fees and use Autodesk's product if it in fact is able to perform as well as Carlson.
    Please use plain text.
    AllenJessup
    Re: Survey Package
    03-29-2010 09:33 AM in reply to: wdbar
    The technical answer to your question is yes. Improvements in the 2010 release have help in automatic linework. But I would also say that while it may preform as well as other software it also is very different from say Carlson. So you would need to allow for the learning curve. A potentially lager learning curve
    Allen
    *Laurie
    Re: Survey Package
    03-29-2010 02:42 PM in reply to: wdbar
    Hi Allen,
    At least you will feel good after enough of the "lager" :-)
    Laurie Comerford
    > Allen
    AllenJessup
    Re: Survey Package
    03-30-2010 05:44 AM in reply to: wdbar
    Laurie,
    If I could spell I wouldn't be working here! If I could drink I would explore that learning curve to the fullest!!
    Allen
    *MWhite
    Re: Survey Package
    04-09-2010 06:31 AM in reply to: wdbar
    Speaking from the standpoint of a designer/drafter user who just tried
    to get a survey department to adopt Civil3D for much the same reasons
    you posit, I would suggest that there are some functionality holes in
    the product from a surveyor standpoint. While the recent reorganization
    of the design tools in the ribbon have made the drafter's work fairly
    slick, and the designer's world a 'simple' progression from left to
    right across the ribbon. The questions I was posed during the
    demonstration for the surveryors were:
    Where is the inverse command? can I take the whole project and
    intelligently migrate it from an assumed coordinate system to a public
    coordinate system through the modification of a couple of control
    points? Our guys use yellow-box equipment, and the answers we found
    were that they would continue to need to use software from the hardware
    vendor to perform geodetic adjustment. (answer both from survey vendor
    and autodesk support). So, surveying package? NO. Very capable
    drafting integration for pre-adjusted survey data? YES.
    Linework and node/point/block placement (layer/color/style/etc) in C3D
    is excellent, once you have the coding system consistent between field &
    office (Learning curve mentioned by others), BUT your linework is all a
    very special type of object called a survey figure, which is really
    really awesome, if you need it to be a 3D object that is useful for
    generation of a surface model. Oh, and linetypes don't propagate
    properly. So you may end up taking all this automatic linework for
    fences for example, and exploding it (twice), and flattening it, and
    "pedit"ing it back together. Which is faster than finding all the
    points that are coded FNC and connecting the dots, usually.
    Not quite a ringing endorsement yet, eh? So, here's the bottom line.
    We use civil3d exclusively for our design and drafting purposes, I
    wouldn't have it any other way, it's the most amazing tool I've ever had
    the opportunity to use as a designer. As long as you're not expecting
    geodetic magic or other very-surveyor-specific tools to be easily
    accessible, drop the third-party software and wade through the C3D
    solution, all the old Autodesk Survey functionality is still in the
    program, it's just in several locations, and was not intuitive for the
    surveyors in the office in which I work. Whatever tools they are
    currently using to communicate with the data collector(s) will still
    need to be used, and if that is the 3rd party application . . . .
    For us, I was able to keep us from acquiring a seat of the software you
    mention, but only because of the learning curve associated with ANY
    piece of software, and I demonstrated that I could do the drafting they
    wanted in C3D very quickly.
    The upshot for me is that I get to do a LOT more drafting work for the
    survey division, which means I get to go to work almost every day of the
    week, and I'm learning a lot about surveying. So I am grateful to
    Autodesk for hiding the survey tools in places only a geek like me would
    think to look.
    Matt
    The views expressed here are not necessarily those of me, my peers, or
    any person real, historical or imagined.
    New Member
    ToddMtnBkr
    Re: Survey Package
    12-02-2010 05:17 AM in reply to: wdbar
    Thanks for that post...
    I'm and LSI and have used Carlson and Eagle Point in the past and have been recently (about 6 months ago) convinced by our drafting/engineering department to switch over to 2011 C3D so that our work flow could more easily flow back and forth (from our surveying company/department to our engineering department).
    It has taken me a while to get used to C3D, and I still miss a number of functions in the more survey friendly 3rd party surveying software, but since we do a significant amount of topo for our engineering/design I've come to appreciated C3D more than I anticipated I would (the figures are quite nice to work with in creating and cleaning up a surface).
    I would agree that you need to manipulate (translate and/or rotate) your data in your data collector before dumping to C3D but I have found that it is possible (although quite cumbersome) to do through the survey database.
