• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Survey Products
    *jon
    Help creating a horizontal taper traverse
    80 Views, 0 Replies
    09-27-2008 09:24 AM
    I have been using autocad for a while now and can't get a simple horizontal
    alignment report including the coordinate of the bc,ec pi coordinates of
    curves for the alignment taper. I will try to explain a little bit what I
    would like. I currently have a alignment (see below) with curves. From that
    alignment I have a new alignment based on a offset distance. As you can see
    the new alignment is not all copy parallel distance.What I would like is
    that all offset distance be in a taper on tangent and if it is on a curve I
    would like a best fit curve (repeat best fit curve) no compute curve by two
    know points all reference to the main alignment.
    Any help would be appreciated.
    Station North Easting Radius
    717+30.66 1903527.8828 6251454.9240
    718+82.38 bc 1903675.8828 6251787.8700
    721+31.94 ec 1903918.5372 6251456.9455 361'
    724+07.32 bc 1904163.7574 621331.6390
    726+08.37 ec 1904356.2747 62251278.7536 492'
    736+02.31 bc 1905348.1958 6251215.4053
    745+46.33 ec 1906078.1079 6250695.3235 850'
    746+84.14 1906161.3180 6250568.1980
    Right tw. station Right tw offset transition
    715+50 11'
    717+50 12'
    720+22 12'
    725+22 24'
    728+40 24'
    728+75 24'
    733+75 12'
    742+92.826 12'
    744+50 12'
    746+50 11'
    Please use plain text.
