Autodesk Survey Products
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Geodimeter Processing Software
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
208 Views, 5 Replies
12-16-2003 06:43 AM
I'm looking for software that will process Geodimeter .RAW files and create .DWG suitable for LD3 (ie faultlines and points as defined by surveyor). Also need the ability to place blocks on layers by code and draw lines(with 3 point arcs) as defined in field. If surveyed correctly, should need no intervention other than rotating text. Current software is FSP (made by MTE Engineering) but runs in DOS.
*cadguy
Re: Geodimeter Processing Software
Options
- Highlight
- Email to a Friend
12-19-2003 06:43 AM in reply to:
egroskopfs
Where are you getting eh Geodimeter files? I you are downloading the files
with Geodimenter software can the software translate the files to other
formats?
"ernieg" wrote in message
news:27022289.1071804784723.JavaMail.jive@jiveforu m1.autodesk.com...
Options
- Highlight
- Email to a Friend
12-19-2003 08:40 AM in reply to:
egroskopfs
We create the RAW files with total stations and download them to a PC. The files have some intelligence built into them ie linework, curves as well as the usual codes that correspond to appropriate symbols. Our current software (the old stuff) takes this RAW file and converts it to DXF which becomes the basis for design. All the linework and symbols are automatically created as are fault lines and points for LDD. I'm looking for something to replace this - I don't want to move backwards and have to join points manually.
*cadguy
Options
- Highlight
- Email to a Friend
12-19-2003 02:29 PM in reply to:
egroskopfs
Using the Survey module of Land Desktop you can convert most raw format
files to a Softdesk Field book. From the fieldbook points can have symbols
automatically inserted and labeled, and figures (lines) can be drawn
automatically. The figures are created on individual layers and converted
to breaklines.
Why are you looking to replace your current system?
news:4997114.1071852082364.JavaMail.jive@jiveforum 1.autodesk.com...
Options
- Highlight
- Email to a Friend
12-22-2003 05:16 AM in reply to:
egroskopfs
We have to use V12 in DOS - good reason to upgrade?
Is there a spec for FBK file - I seem to remember it didn't even use coordinates - it used angles and distances from setup point - seems strange when coordinatea are already calculated in RAW file.
*cadguy
Options
- Highlight
- Email to a Friend
12-23-2003 01:46 PM in reply to:
egroskopfs
Do you have a version of the Survey module for Land Desktop?
I noticed on the Survey module does have download and file conversion
routines for the Geodimet instruments including: GEODAT 400, 402, 500,
GIODIMETER internal memory utilities, GEODIMETER 4000 CU Utilities, and
GEODIMETER 600 Utilities.
Gordon
news:2758933.1072099057686.JavaMail.jive@jiveforum 1.autodesk.com...
