• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Survey Products
    New Member
    Duplicate Point Numbers
    77 Views, 1 Replies
    10-10-2003 06:11 AM
    When I import points from a .fbk file into a drawing I get duplicate text for the point number. The typical point block comes in fine, but I get extra text containing the point number. It is just text and doesn't appear to be part of the point block. The extra text can readily be erased, but it is a pain.
    I have been using the software for years with no similar problem. Is there a setting that might have been changed?
    Please use plain text.
    Re: Duplicate Point Numbers
    12-09-2003 10:31 PM in reply to: jsladge
    It is just a Point Label Style,
    if you go to Labels
    Point Labels
    Edit Label Style
    Point Label Style tab
    from here you can change the label
    style, layer, nothing at all)
    it is straight forward
