• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Survey Products
    Drawing a spline in 3d
    338 Views, 10 Replies
    12-17-2008 04:29 AM
    how do u draw a spline in 3d. we are trying draw linework with a spline. this works in 2d but does not create a breakline.
    Please use plain text.
    *Laurie Comerford
    Re: Drawing a spline in 3d
    12-19-2008 11:44 AM in reply to: MJONES1924
    Hi MJONES1924,
    You draw splines in Civil 3D with the normal AutoCAD Spline command.
    However, Civil 3D does not recognise a spline for any purpose, so if you
    wish to get Civil 3D information from a spline, the simple answer is -
    you can't.
    The slightly more complex answer is that you can convert the spline to a
    polyline and get data from the polyline.
    Regards
    Laurie Comerford
    12-19-2008 12:36 PM in reply to: MJONES1924
    so how do u convert a spline to a polyline?
    *Laurie Comerford
    12-19-2008 03:56 PM in reply to: MJONES1924
    Hi MJONES1924,
    Some ways.
    * Draw it as a polyline first time.
    * Trace over it as best you can.
    * Search the web for conversion programs.
    I seem to remember that Terry Dotson has one at www.dotsoft.com
    Regards
    Laurie Comerford
    *Jon Ras
    12-20-2008 10:11 PM in reply to: MJONES1924
    I'm a surveyor, and this is the survey products
    newsgroup, so I feel I can point out that I would hate to be given spline
    geometry to set out: you sure you don't want to use polylines with filleted
    arcs?
    I remember 6 years ago when I was the project
    surveyor for a defence accommodation job: the architects supplied autocad
    drawings of carparking and access roads with splines and levels here and there.
    Had to use a bob-cat to shape it 'cause there were
    no constant grades: cost went through the
    roof.
    Looked
    lovely on the plan tho:smileyhappy:
    size=2>
    Jon Rasmussen
    href="http://www.StringerSurvey.com">www.
    size=3>StringerSurvey
    .com
    how
    12-21-2008 02:55 PM in reply to: MJONES1924
    well i have not used splines for contouring and breaklines in LLD2004. and if we did we use a spline, we would just trace right over the splines cause there were splines and they held no Z values so we created a breakline from point proxy. I did not know if AutoCADD did resolve this issue with 2007 and Civil3d apparently not. I have been using the Fit command in the Pedit command has been working fine, accept when we come to a ditch that is not so symetric. So i guess that next question is how do u make the fit command in the pedit command not make things so symetric not all cases need to be symetric like creeks ditchs and other natural objects.
    *Jon Ras
    12-21-2008 11:09 PM in reply to: MJONES1924
    Are you saying you use the fit command on surveyed
    breaklines?
    well
    12-22-2008 03:57 AM in reply to: MJONES1924
    yeah i am using the fit command on the survey lines is that wrong?
    New Member
    03-03-2009 12:24 PM in reply to: MJONES1924
    A true 3d spline is very good and goes thru the points and AutoCAD can not do it. AutoCAD only do a best fit between the points like for chemistry report or for architects, but for surveyors they need it to go thru the points. It is very easy to program but they choose not to. I tried to give the math and algorithm in the early 90’s but they did not care about surveyor and evident by release 2009.
    *Laurie Comerford
    03-03-2009 02:19 PM in reply to: MJONES1924
    Hi
    size=3>white40
    Your comments seemed unusual to me and not within
    my experience so I looked up Wikipedea:
    <Quote from Wikipedea>
    "In
    href="http://en.wikipedia.org/wiki/Mathematics">mathematics
    , a spline
    is a special
    href="http://en.wikipedia.org/wiki/Function_(mathematics)">function
    defined
    piecewise
    by
    href="http://en.wikipedia.org/wiki/Polynomial">polynomials
    . In
    title=Interpolation
    href="http://en.wikipedia.org/wiki/Interpolation">interpolating
    problems,
    title="Spline interpolation"
    href="http://en.wikipedia.org/wiki/Spline_interpolation">spline
    inte...
    is often preferred to
    href="http://en.wikipedia.org/wiki/Polynomial_interpolation">polynomial
    interpolation
    because it yields similar results, even when using low degree
    polynomials, while avoiding
    href="http://en.wikipedia.org/wiki/Runge%27s_phenomenon">Runge's phenomenon
    for higher degrees.
    In the
    href="http://en.wikipedia.org/wiki/Computer_science">computer science
    subfields of
    href="http://en.wikipedia.org/wiki/Computer-aided_design">computer-aided
    design
    and
    href="http://en.wikipedia.org/wiki/Computer_graphics">computer graphics
    , the
    term spline more frequently refers to a piecewise polynomial
    class=mw-redirect title="Parametric curve"
    href="http://en.wikipedia.org/wiki/Parametric_curve">(p...
    title=Curve href="http://en.wikipedia.org/wiki/Curve">curve
    . Splines are
    popular curves in these subfields because of the simplicity of their
    construction, their ease and accuracy of evaluation, and their capacity to
    approximate complex shapes through
    href="http://en.wikipedia.org/wiki/Curve_fitting">curve fitting
    and
    interactive curve design.
    The term spline comes from the flexible
    href="http://en.wikipedia.org/wiki/Flat_spline">spline
    devices used by
    shipbuilders and
    href="http://en.wikipedia.org/wiki/Technical_drawing">draftsmen
    to draw
    smooth shapes."
    <End Quote from Wikipedea>
    Within this definition it is quite clear that a spline does not pass through
    the control points.
    It is now over 50 years since I first started doing survey work and have
    worked in the Civil/Survey field for that time.
    The item by Jon was the first time I had ever heard of splines being used in
    this area and it was quite clear from his post that the result was not one which
    would lead anyone wanting to repeat that exercise.
    What sort of survey work do you see needing a spline?
    Laurie Comerford
    A
    by release 2009.
