• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Survey Products
    Active Member
    Drawign Coord vs. Network Coord.
    144 Views, 3 Replies
    10-09-2008 01:53 PM
    I'm having a problem importing .fbk files. When I import a .fbk file into a survey network I have Insert figure object and Insert survey points checked. The survey network coordinates match the .fbk file just fine. However, the drawing coordinates are shifted about 4 feet. I've checked to make sure the Survey database is set to US Survey Feet. There is no projection and no measurement corrections selected. Any ideas as whats going on would be greatly appreciated.
    Here's my .fbk file:
    !FBK file created by Field Data Extractor v3.1.1
    !Date (creation): 2008/10/06 09:07:40
    !Date (last modification): 2008/10/06 09:07:40
    JOB "10-6-08 1246.01"
    UNITS USFOOT DMS !US Survey Foot
    HORIZ ANGLE RIGHT
    VERT ANGLE ZENITH
    !Instrument Model: TCRP1203 Serial: 226466 Name: TCRP1203
    NEZ 1 388367.7700 2117711.5100 4985.9700 "103"
    NEZ 5 388287.8990 2118437.8240 4984.4260 "103"
    !Setup Date: 2008/10/06 09:19:21 Method: Known backsight point
    !NEZ 1 388367.7700 2117711.5100 4985.9700 "103"
    STN 1 5.560
    !NEZ 5 388287.8990 2118437.8240 4984.4260 "103"
    BS 5 96.16317
    Please use plain text.
    Active Contributor
    Re: Drawign Coord vs. Network Coord.
    10-09-2008 03:00 PM in reply to: schockd
    A us survey foot is 1.000002.. times larger than an international foot. If you multiply your coordinates shown below by that factor the resulting location is about 4 feet away. Check your setting in the prospector. I bet it is set it feet and not us survey feet
    Active Member
    10-09-2008 03:04 PM in reply to: schockd
    I've checked that and verified that all settings are using US Survey feet, but I'll check again....
    Distinguished Contributor
    11-21-2008 02:19 PM in reply to: schockd
    The survey itself has specific settings.
    make sure haven't accidentally assigned your survey a coordinate zone. When a projection is assigned to a survey, the program will process scaling to your survey data when it gets inserted into the drawing.
    Certainly if the drawing has no projection, it will think it is receiving International feet. BUT - if your survey database has a projection/zone assigned to it, the survey thinks it is in US Survey feet.
    Hence, you will most certainly see a US Surveyfoot/International foot conversion occur at import.
    Remember:
    1 US Survey Foot = 1200/3937 m
    1 International Foot = 0.3048 m
    __________
    Craig T. Bailey, PE
    Civil Engineering Consultant
