Autodesk Survey Products
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*colton
Dimension Styles
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
49 Views, 2 Replies
10-07-2003 03:58 AM
Does anyone know if Autodesk Field Survey supports Dimension Styles.. I've
been using the "offset dimension" command, but would like to modify it. Any
help with this would be greatly apperciated.
Colton Hall
Colton Hall
*Ran, Nava
Re: Dimension Styles
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-07-2003 07:02 PM in reply to:
*colton
DIMSTYLE is read-only.
Annotate>Survey Text Defaults sets the defaults for the Offset Dimensions.
Under Dimension Line Type, you can determine the line style to use for
dimensions.
"colton" wrote
news:2F135A45AA73DF5C8D3786A3DDE0E172@in.WebX.maYI adrTaRb...
Any
> Colton Hall
dimensions.
"colton"
Any
> Colton Hall
*McSwain, R.K.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-07-2003 10:49 PM in reply to:
*colton
"colton" wrote in message news:2F135A45AA73DF5C8D3786A3DDE0E172@in.WebX.maYI adrTaRb...
Of course it supports dimension styles, meaning it uses them. But there is no command to create, delete, or edit dimension styles.
You could create an empty drawing using full-blown AutoCAD that contains all the dimension styles that you want, then use this as a prototype or insert it into any existing drawing. I'm not sure there is any way to *set* a dimstyle current though. This probably won't help much anyway since the dimensioning commands in AFS set certain dimension variables at run-time, essentially hard-coding the output.
