Autodesk Survey Products
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Converting to FBK
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
128 Views, 3 Replies
08-12-2008 06:02 PM
Hi!
I don't really know how to put this one...I have a client who wants to know if this can be done in Survey (in Civil 3D 2009): Whenever they will survey a foot path, a drain (or anything that can be redundantly) they only do the sightings on one side and will just assign a figure for the other side. Using their old software, this will only be plotted as a single line. The question is, upon Conversion to FBK file, can Survey plot a double line representing both sides of the foot path or drain? Thanks!
*Laurie Comerford
Re: Converting to FBK
Options
- Highlight
- Email to a Friend
08-12-2008 06:28 PM in reply to:
mbyee28
Hi glimor's girl,
Search the Civil 3D help files for "Survey Command Syntax", Select the
Survey Command Language (the top item returned by the search), then
Select the Figures commands
There is a reference to an OFFSET function.
However, there are several links in the chain of entering the data to
your model data recorder, whether the programmer who wrote the code to
translate your raw observed/annotation data to the proper fieldbook
format. Experiment with hardware and software combinations are needed.
Post your hardware details and a user here may have resolved the issue
for that hardware.
There is an excellent solution to this issue using "Stringer" which
allows multiple offsets and vertical as well as horizontal offset. You
can find more details at:
http://www.stringersurvey.com/
Regards
Laurie Comerford
glimor's girl wrote:
> Hi!
for that hardware.
Regards
Laurie Comerford
> Hi!
Options
- Highlight
- Email to a Friend
08-12-2008 08:36 PM in reply to:
mbyee28
Hi Laurie!
Thanks for the reply. I've tried using OFFSET in Survey command window and it works. However, the main concern of the client is if it's possible not to go through this process manually. They are talking about some libraries wherein everytime they import the FBK it will automatically plot the offset with such settings. Does this make sense?
*Laurie Comerford
Options
- Highlight
- Email to a Friend
08-13-2008 02:47 AM in reply to:
mbyee28
Hi glimor's girl,
Here's a simple little fieldbook data set. Copy it to a fieldbook file
and import it. It will display the capability of the fieldbook. Do an
AutoCAD list of the offset object, or look at it from the Survey
Database in the Prospector. But remember that you have to be able to
input the data in your data recorder and the transformation software has
to do the transformation, neither of which is guaranteed.
NEZ 1 10 10 10
NEZ 2 10 30 10
BEG Fred
PT 1
PT 2
OFFSET FRED 10
NEZ 3 15 40 10
Change the text to:
NEZ 1 10 10 10
NEZ 2 10 30 10
BEG Fred
PT 1
PT 2
NEZ 3 15 40 10
OFFSET FRED 10
and import again.
Regards
Laurie Comerford
> Hi Laurie!
NEZ 1 10 10 10
NEZ 2 10 30 10
BEG Fred
PT 1
PT 2
OFFSET FRED 10
NEZ 3 15 40 10
Change the text to:
NEZ 1 10 10 10
NEZ 2 10 30 10
BEG Fred
PT 1
PT 2
NEZ 3 15 40 10
OFFSET FRED 10
and import again.
Regards
Laurie Comerford
> Hi Laurie!
