• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Survey Products
    IanMcClain
    Autodesk .fbk documention
    1229 Views, 3 Replies
    07-11-2011 11:08 AM
    Is ther a web link or pdf anyone can point me to for somekind of Autodesk refrence documentation of fieldbook .fbk commands/codes/language? I have an old LDD Survey manual, but it doesn't always answer my questions. The Civil3D documentation for fbk tells you how to import but nothing about editing content. I learned from a post on this board that an NEZ can coded as NE SS so that it doesn't come in as a control point. There has to be some kind of Autodesk documentation for those kinds of commands.
    -Ian McClain
    (running C3D 2012 sp3, Win7 64bit)
    Please use plain text.
    Member
    rrenteria
    Re: Autodesk .fbk documention
    07-11-2011 12:45 PM in reply to: IanMcClain
    Look in folder C:\Program Files\Land Desktop 3\Data\Survey\lng of LDD3 installation for file named cmdhelp.ref. Commands may have been added/removed in later releases of LDD. I am not sure where the installation files are for latest release of LDD (9), but I believe the file name is the same as noted above.
    IanMcClain
    07-13-2011 06:50 PM in reply to: rrenteria
    I don't have Land Desktop installed.
    -Ian McClain
    Member
    rrenteria
    07-14-2011 04:12 AM in reply to: IanMcClain
    Find attached. I had to rename to *.txt in order to attach. This file came from LDD 2005.
