• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Moldflow Adviser
    New Member
    Accepted Solution
    units for mfr file
    212 Views, 2 Replies
    06-26-2012 07:37 AM
    When creating a MFR file, how do you control what the output units will be?
    Would like to have dual units (english/metric)
    Please use plain text.
    Product Support
    Shawn_Gedman
    Re: units for mfr file
    06-29-2012 06:15 AM in reply to: mlentz
    There is no need to assign units when exporting an mfr file for Communicator since they'll be maintained automatically after the model is imported into Adviser.  We can change the units that you're viewing the model and plots in after importing the model though.
    To change the display units in the Ribbon, open the Application menu, select Options, and you may change the display units in Communicator between English and Metric right on the General tab.  For the Classic interface, go to File, select Options, and change the units on the General tab.  Unfortunately Communicator does not have the option to view the model in dual units like Adviser does.
    New Member
    12-12-2012 08:41 PM in reply to: mlentz
    hi,
    The defult units are published in creation of .mfr.You can change the default unit system as per your requirement.
    nsanwal
