• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    New Member
    yaman41
    temperature at flow front
    414 Views, 2 Replies
    03-20-2012 04:15 AM
    I've performed an analysis in insight.Please look to attachments.There is a problem with the temperature at flow front result. The temperature value is very high in some regions and also the temperature difference is high on whole part.What can i do about this problem?
    Are there any way to catch more appropriate values?
    Please use plain text.
    Board Manager
    raalteh
    Re: temperature at flow front
    03-30-2012 05:02 AM in reply to: yaman41
    If you look at the normal temperature plot, does it look spotty as well? Particularly the inside.
    Hanno van Raalte,
    Product Manage for Autodesk Simulation Moldflow products
    Active Contributor
    04-10-2012 09:36 AM in reply to: yaman41
    I would look at
    1. Fill time control.
    2. Part Thickness – gate size.
    3. Waterline setting.
    1. Is the fill time the optimal one? Longer fill times tend to create flow front temperature reductions. And short fill times create shear heating increasing flow front temperature.
    2. Larger part thickness variations create the same change on the flow front temperature. Small gate size will create excessive shear heating on the plastic increasing flow front temperature.
    3. Are the waterlines cooling the flow, creating turbulence?
    You can check more of this on the help-tutorial area.
    Good luck!
    Hugo Herrera
