• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    Active Member
    mayur_dhumal
    Accepted Solution
    "Allow Docking" option isn't available, All panels are floating.
    283 Views, 3 Replies
    04-04-2012 01:02 AM
    As you can see in attached file i am not able to see "Allow Docking" option in my Autodesk moldflow insight 2011.
    All panels are freely floating.
    can anyone please help me in this regards?
    help would be highly appreciable.
    Mayur D.
    Please use plain text.
    Active Member
    mayur_dhumal
    Re: "Allow Docking" option isn't available, All panels are floating.
    04-10-2012 03:40 AM in reply to: mayur_dhumal
    Does any Moldflow Developer here, can support in this regards?
    Product Support
    04-10-2012 04:12 AM in reply to: mayur_dhumal
    what you can do is:
    If a pane will not dock, right-click anywhere in the border of the pane and ensure that Allow Docking is selected.
    (recommend use the border at left, bottom, or right  of the pane for the right-click, as top is for the move)
    The one can dock again.
    or
    Start > Programs > Autodesk > Autodesk Moldflow Insight 2011 > Autodesk Moldflow Insight 2011 Command Shell
    cleanreg <enter>
    This will reset personal settings and parameters, and the menus will be docked when starting Synergy.
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    mayur_dhumal
    04-10-2012 04:37 AM in reply to: nordhb
    Thanks Berndt,
    second option has worked for me.
    Mayur Dhumal.
