• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    ramabalaji
    need of acess point for downloading the updated UDB file from autodesk
    255 Views, 5 Replies
    08-11-2011 11:50 PM
    Dear all, could you please share the link for downloading the latest UDB file autoderatories,
    more over it is also observed that most of material in the library does not posses shrinkage details, which becomes must for performing shrink analysis,
    pl advice
    Thanks, Ramabalaji.K
    Please use plain text.
    Product Support
    Re: need of acess point for downloading the updated UDB file from autodesk
    08-16-2011 03:39 AM in reply to: ramabalaji
    the material database is updated together with software release, and will be available when installing the software.
    You can access the latest release of Autodesk Moldflow Insight 2012 Service Pack 2, at the subscription center:
    http://subscription.autodesk.com/
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    Autodesk, Inc.
    ramabalaji
    08-17-2011 12:16 AM in reply to: nordhb
    Thank you sir,
    but the for user who do not update their software licence with AMC it becomes impossible to get acess to latest material database,
    requesting the concern's to take in account of the mentioned issue and create a centralised data access point,
    regards, ramabalaji
    Employee
    08-17-2011 03:45 AM in reply to: ramabalaji
    AMC doesn't have material database.
    The material data are saved in the mfr file.
    Active Member
    mohdazaman
    08-06-2012 07:33 PM in reply to: nordhb
    If we use AMI 2011, can we update our material database with AMI2012 SP2 ?
    Board Manager
    raalteh
    08-07-2012 04:35 PM in reply to: mohdazaman
    At the mioment, there is no online material database, although there are plenty of valid use cases for this.
    Having said that, the material databases are tightly related to the solvers, so you would have to be careful with these things.
    Hanno van Raalte,
    Product Manage for Autodesk Simulation Moldflow products
