Autodesk Simulation Moldflow Insight
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
modeling bubbler
- Highlight
- Email to a Friend
hi every one ,
for my anlysis i need a bubbler cooling system , i have draft that with the help of the instruction in the help (modeling bubbler )
but every time after the mesh my bubbler have intersetion , i have try the the mesh repair Winzar to corect the intersection , but nothing change .
so if same one can help me please.
thank u so mutch
samica ![]()
Re: modeling bubbler
- Highlight
- Email to a Friend
Try running the analysis. The intersection might be OK (as long as the part mesh has no intersections).
It may be just how the bubblers are modeled. Did you have overlapping curves for bubblers (which is acceptable). Even if no overlapping curves it may still show intersections. Just make sure that the bubblers dont intersect with the part mesh.
- Highlight
- Email to a Friend
Thanks for reply
the part mesh have not intersection , the intersection are in the bubbler , i have run the analysis and she was succesful with 7 warrning, the result of the the warp is olso get better , but i dont now if thos intersection dont make the anlysis not good , and how can i solve those warning .
thanks so much ( and sorry for my bad english )
samica
- Highlight
- Email to a Friend
Bubbles are always giving error warnings .... ignor them in most cases.
I suggest you make a "dummy" file with a "bubbler" , anoterh with a thermal pin , etc. in a "tooling" master project.
Then just "add" the geomtry to the part you are evaluating and modify ( length usually )
Hope that makes sense
- Highlight
- Email to a Friend
The troubles of overlapping are normal with bubblers.
You can see where they occur using the tool : mesh / diagnostic / overlaping.
For cooling analysis, the main problem is when the calculation is unable to converg.
Take care about these warnings in the summary.
To solve them, the size of channels mesh have to be clearly bigger than the one of the part.
(I believe 2.5 times. Control this in the Help)
But, it is often not possible all along the channels.
- Highlight
- Email to a Friend
The picture joined shows an example of the overlapping diagnostic you get with bubblers.
As I said before, this is normal and do not cause cooling analysis errors.
- Highlight
- Email to a Friend
Firstly, I confirm that the intersection are normal with bubblers, baffles and in general with beam elements, but this condtion has not negative effects on the analysis.
I have now a question for you on the modeling of the bubblers:
looking the help is clear that when you draw a baffle the final node must 1/2 diam. shorter than the real hole, but it's not specified for the bubbler. Actually I put the node at the same level of the extremity of the hole, but I'm not sure about it.
Has someone verified this thing ?
Thanks to all
Alessandro
- Highlight
- Email to a Friend
For both Baffles and Bubblers, the top node must be half the diameter below the drilled hole. This is because the solver will add half the diameter to the node position during the cool analysis.
As for the intersections, this is normal in a cooling circuit. It is important that the global edge length of your cooling channels is set to be 2 to 3 times the diameter of the cooling channel. If the cooling line diameters are significantly different, the global edge length should be changed for the various diameters.
Paul Larter
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hello!
I would like to ask a question about modelling a baffle. I understand the meshing method and the two overlapping beam element. My question is about the diameter of the to beam elements.
If i have a baffle than I should use the same diameter for both of the beam elements which are the outer diameter of my baffle? Please see attached picture.
If I use a bubbler, than I should use different diameters, one for the inner pipe of the bubbler and one for the outer pipe?
Thanks!
BR
András
- Highlight
- Email to a Friend
Hello!
I also have another question about the last node of the baffle.
It is written here eariler:
"For both Baffles and Bubblers, the top node must be half the diameter below the drilled hole. This is because the solver will add half the diameter to the node position during the cool analysis."
But is it depends on the coordinate system?
Please see the attached picture. In my opinion the blue heat zone should be higher and for me it looks like that the solver put this half diameter to the wrong direction. Is it possible? Please check the coordinate system in the left bottom corner.
BR,
András
