• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Moldflow Adviser
    Distinguished Contributor
    importing iges curve
    443 Views, 2 Replies
    04-13-2010 02:24 AM
    Hi!
    Importing iges curves for feed and cooling system from Pro-E wildfire 4.0, the measure of the channel is wrong.
    Even if I have the same settings (mm) on both Pro-E and Moldflow, after the import the channel are in (inch x 10).
    Anyone know how can I do without rescaling in the CAD?
    Thank you in advance
    Marco
    Please use plain text.
    Active Member
    Re: importing iges curve
    04-13-2010 06:33 AM in reply to: subpartner
    Marco,
    Which measurement is wrong? The diameter or the spacing? When I use the import runner function on AMA2010-R2, the runner diameter is based on the current default setting, not anything from CAD. (I import from I-Deas).
    Check out this article for a how to.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14913760&linkID=13030537
    Martin Schultz Edited by: MartinSchultz on Apr 13, 2010 9:36 AM
    04-16-2010 08:18 AM in reply to: subpartner
    thank you Martin, but the problem is about the curves' lenght. The leght in moldflow is 25,4 times more than real (2,54 factor mm-inches x 10 [i don't know, seems to be in centimeters instead mm]
    I know ho wto set before the diameter, but probably is an option in Pro-E to let MOldflow recognize the correct unit system.
    Bye
    Marco
