• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Adviser
    Valued Contributor
    Windows 7 Professional absolutely required?
    369 Views, 1 Replies
    01-10-2011 10:23 AM
    One of my prospects is asking whether he could run AMA on his laptop, under Windows 7 Home Basic. Now, in the Release Notes it's stated that the minimum requirement is W7 Professional...
    My question (out of curiosity): which AMA/AMI functionalities are NOT functioning under W7 Home Premium, and which Professional OS features are required?
    Cheers
    Piotr
    Please use plain text.
    Re: Windows 7 Professional absolutely required?
    01-30-2011 03:49 PM in reply to: p.wozniacki
    Hi Piotr-
    as this is a user forum, You may have more luck if you contact your autodesk support or supplier directly?
    Personally I run win7 pro 64bit, and will not waste my time trying to save a few hundred dollars on a decent OS, as the time savings alone will soon cover the cost of the better OS.
    :smileyhappy:
