• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    New Member
    Using an STL File as the Mesh for Analysis in Insight
    134 Views, 1 Replies
    07-10-2012 07:04 AM
    I am having difficulty creating a mesh for parts in Insight that have a low maximum Aspect Ratio, while remaining an accurate representation of the part geometry.  Some parts imported have too many radii and specific geometry to remove before meshing in Insight.
    I can create a better mesh of a part by creating an STL in MagicsSTL 4.0, but the part has to be meshed again before analysis in Insight.  Is there a way to use the STL mesh in the Insight analysis?
    Thanks in advance.
    Please use plain text.
    Employee
    Re: Using an STL File as the Mesh for Analysis in Insight
    07-23-2012 11:17 AM in reply to: Nick182
    There is a back-door mechanism to enable this workflow (this is however, an unsupported workflow formally). If you contact your support representative, they may be able to provide you details on how this could be done.
