• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    Tooling graphics not inline with dimensions
    267 Views, 6 Replies
    04-09-2012 11:01 AM
    Wondering if anyone knows "why" when you set a beam size it shows much larger when the results are plotted. I know my customers will ask why the gates appear to be so large in the results.
    Please see the attached pictures.
    Thanks.
    Please use plain text.
    Re: Tooling graphics not inline with dimensions
    04-09-2012 11:06 AM in reply to: lznv0f
    This has been reported as a bug thru support, but yet to see a fix.. Very annoying to explain to your customers time after time.
    Active Contributor
    tim.vanast
    04-10-2012 05:47 AM in reply to: lznv0f
    but the results are correct for the size you specified, not the large size that is seen in the output plots.
    Valued Contributor
    PascalGosset
    04-10-2012 06:00 AM in reply to: tim.vanast
    To Tim : it's false !
    The results correspond to the gate section seen by Moldflow (a square) not the one you drawned (rectangular).
    If you want to simulate a fan gate, modelize it using dual domain mesh and not beams.
    "Maybe Moldflow does not work properly, but the real world neither."
    Active Contributor
    tim.vanast
    04-10-2012 06:15 AM in reply to: PascalGosset
    Interesting, I was told by MF support that it calculates correctly.  I'll have to run a case study to see.
    Tim
    04-10-2012 07:24 AM in reply to: lznv0f
    It's only a display issue. I've ran many, many analysis over the last year and half with this visual issue. The assigned properties are used for calulations, not the visual size... otherwise the results would be completely screwed up...
    Valued Contributor
    PascalGosset
    04-10-2012 07:54 AM in reply to: toofewfish
    Sorry, I'm maybee wrong.
    I tried to find an example and it doesn't work as I thought.
