• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    Valued Contributor
    Save Quick Access Toolbar
    113 Views, 2 Replies
    08-01-2012 08:49 AM
    Hi, I've putted some tools in the Quick Access Toolbar.
    When I close Moldflow and I start it again the tools there are no more.
    It seems not to be saved.
    If I open the file SynergyState_enu.xlm in the
    ....\AppData\Roaming\Autodesk\Autodesk Moldflow Insight 2012\Release
    I see:
      <QuickAccessToolBars>
        <QuickAccessToolBar ContentFile="/AirSynResourcesI18n;component/Resources/Xml/SynergyRibbon.xml">
          <Content DefaultCommands="31">
            <Items Count="14" AreCustomizeVisibilityItemPositionsFixed="True">
              <Item Cookie="Item=ID_New_New Project_" IsVisible="True" />
              <Item Cookie="Item=ID_Open_Open Project_" IsVisible="True" />
              <Item Cookie="Item=ID_ImportGeometry_Import_" IsVisible="True" />
              <Item Cookie="Item=ID_Save_Save Study_" IsVisible="True" />
              <Item Cookie="Item=ID_Undo_Undo_" IsVisible="True" />
              <Item Cookie="Item=ID_Redo_Redo_" IsVisible="True" />
              <Item Cookie="Item=ID_ActionHistory_Action History_" IsVisible="True" />
              <Item Cookie="Item=ID_Print_Print_" IsVisible="True" />
              <Item Cookie="Item=QAT_Sep1_Separator_" IsVisible="True" />
              <Item Cookie="Item=ID_QATCapture_Capture_" IsVisible="True" />
              <Item Cookie="Item=ID_CaptureOptions_Capture Options_" IsVisible="True" />
              <Separator Style="Line" Width="7" />
              <Item Cookie="Tab=ID_Reports_Reports_Reports/Panel=ID_ImagesPanel_Image Capture_Images/Item=ID_SaveImageToFile_To File_" IsVisible="True" />
              <Item Cookie="Tab=ID_Reports_Reports_Reports/Panel=ID_ImagesPanel_Image Capture_Images/Item=ID_SaveAnimationToFile_Animation_" IsVisible="True" />
            </Items>
            <StandardItems Count="11">
              <StandardItem Cookie="Item=ID_New_New Project_" />
              <StandardItem Cookie="Item=ID_Open_Open Project_" />
              <StandardItem Cookie="Item=ID_ImportGeometry_Import_" />
              <StandardItem Cookie="Item=ID_Save_Save Study_" />
              <StandardItem Cookie="Item=ID_Undo_Undo_" />
              <StandardItem Cookie="Item=ID_Redo_Redo_" />
              <StandardItem Cookie="Item=ID_ActionHistory_Action History_" />
              <StandardItem Cookie="Item=ID_Print_Print_" />
              <StandardItem Cookie="Item=QAT_Sep1_Separator_" />
              <StandardItem Cookie="Item=ID_QATCapture_Capture_" />
              <StandardItem Cookie="Item=ID_CaptureOptions_Capture Options_" />
            </StandardItems>
    but in "StandardItem Cookie" I see nothing compare "Items Count".
    How can I do?
    thanks
    Please use plain text.
    Employee
    Re: Save Quick Access Toolbar
    08-03-2012 12:58 AM in reply to: biricio
    Did you try with 2013 ?
    There was an issue with 2012 and windows 7 for quick access toolbar which has been solved for 2013.
    Valued Contributor
    08-03-2012 02:49 AM in reply to: yannick.moret
    Hi, thanks for the answer.
    Unfortunately I have the 2012 and my company for now does not want to go to 2013.
    Do you think changing the code (SynergyState_enu.xlm) you can do something?
    thanks
