Autodesk Simulation Moldflow Insight
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Save Quick Access Toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, I've putted some tools in the Quick Access Toolbar.
When I close Moldflow and I start it again the tools there are no more.
It seems not to be saved.
If I open the file SynergyState_enu.xlm in the
....\AppData\Roaming\Autodesk\Autodesk Moldflow Insight 2012\Release
I see:
<QuickAccessToolBars>
<QuickAccessToolBar ContentFile="/AirSynResourcesI18n;component/Resour
<Content DefaultCommands="31">
<Items Count="14" AreCustomizeVisibilityItemPositionsFixed="True">
<Item Cookie="Item=ID_New_New Project_" IsVisible="True" />
<Item Cookie="Item=ID_Open_Open Project_" IsVisible="True" />
<Item Cookie="Item=ID_ImportGeometry_Import_" IsVisible="True" />
<Item Cookie="Item=ID_Save_Save Study_" IsVisible="True" />
<Item Cookie="Item=ID_Undo_Undo_" IsVisible="True" />
<Item Cookie="Item=ID_Redo_Redo_" IsVisible="True" />
<Item Cookie="Item=ID_ActionHistory_Action History_" IsVisible="True" />
<Item Cookie="Item=ID_Print_Print_" IsVisible="True" />
<Item Cookie="Item=QAT_Sep1_Separator_" IsVisible="True" />
<Item Cookie="Item=ID_QATCapture_Capture_" IsVisible="True" />
<Item Cookie="Item=ID_CaptureOptions_Capture Options_" IsVisible="True" />
<Separator Style="Line" Width="7" />
<Item Cookie="Tab=ID_Reports_Reports_Reports/Panel=ID_Im
</Items>
<StandardItems Count="11">
<StandardItem Cookie="Item=ID_New_New Project_" />
<StandardItem Cookie="Item=ID_Open_Open Project_" />
<StandardItem Cookie="Item=ID_ImportGeometry_Import_" />
<StandardItem Cookie="Item=ID_Save_Save Study_" />
<StandardItem Cookie="Item=ID_Undo_Undo_" />
<StandardItem Cookie="Item=ID_Redo_Redo_" />
<StandardItem Cookie="Item=ID_ActionHistory_Action History_" />
<StandardItem Cookie="Item=ID_Print_Print_" />
<StandardItem Cookie="Item=QAT_Sep1_Separator_" />
<StandardItem Cookie="Item=ID_QATCapture_Capture_" />
<StandardItem Cookie="Item=ID_CaptureOptions_Capture Options_" />
</StandardItems>
but in "StandardItem Cookie" I see nothing compare "Items Count".
How can I do?
thanks
Re: Save Quick Access Toolbar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Did you try with 2013 ?
There was an issue with 2012 and windows 7 for quick access toolbar which has been solved for 2013.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, thanks for the answer.
Unfortunately I have the 2012 and my company for now does not want to go to 2013.
Do you think changing the code (SynergyState_enu.xlm) you can do something?
thanks
