Autodesk Simulation Moldflow Insight
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Regarding packing profile
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
275 Views, 9 Replies
06-25-2009 05:31 AM
Hi All,
Hope you are doing well in moldflow (A new one) world.
I have small query regarding Packing profile as below:
One of my friend was facing a warpage for a automotive part (700mmX160mmX15mmX major thickness 3mm) with ASA material. It comes around 1.5 -2 and he wants to reduce further. Warpage values near gate are 1.5 and in the end are coming as 2 mm, which is not acceptable.
- Packing pressure he used was as per calculation and within limit of clamping tonnage by using avg cavity pressure for material.
He tried different comibination but but all were in vain, with little changes (+/-). We discussed a lot and now though to share that with you to find any answer.
Please throw a light on packing profile seting ( I mean if gate are is warping then how to give packing profile and if end of fill area is warping then how to control it with packing profiles).
Nitin
Nitin
Nitin Hadpe
Neilsoft Ltd, Pune, India
Nitin Hadpe
Re: Regarding packing profile
Options
- Highlight
- Email to a Friend
07-04-2009 05:34 AM in reply to:
nitinhadpe
Dear Nitin,
Check frozen layer fraction of end of fill,till that time
pack with higher pressure( 80% of maximum pressure of specified machine).
Then reduce the packing pressure till gate freezing time.
With regards
Madhukeshwar.T
With regards
Madhukeshwar.T
Madhukeshwar Talwar
Fiat-Chrysler India Automotive Pvt. Ltd. Chennai
Cell No: +91-9600060862
mail: madhukeshwart@gmail.com
Options
- Highlight
- Email to a Friend
07-08-2009 02:24 AM in reply to:
nitinhadpe
Thanks for this info Madhu...
Nitin Hadpe
Nitin Hadpe
Options
- Highlight
- Email to a Friend
07-08-2009 09:57 PM in reply to:
nitinhadpe
did u check the gate dimensions and type of gate used.Not every warpage problem be solved with packing profile.
maybe there is not enough packing pressure reaching out to the ends of the part, how far is the end of fill area from the gate location, how many gates are used.
regards
kameshwarang.G
kameshwarang.G
Options
- Highlight
- Email to a Friend
08-13-2009 09:32 PM in reply to:
nitinhadpe
Compare the part freeze time and gate freeze time using frozen layer fraction. If the gate freeze time is less than the part freeze time then increase the dimension of gate to increase the packing time for the part which will help to reduce the warpage of the part. But if the warping area is freezing very fast then it is meaningless to increase the packing time & then you have to thing to change the product design.
Options
- Highlight
- Email to a Friend
08-14-2009 08:39 AM in reply to:
nitinhadpe
Good Day,
One thing I may have missed was the verification that the warpage is primarily caused by Differential Shrinkage (I like to call it area shrinkage) Run the isolate warpage analysis to ensure that this is the primary cause of the warpage. It probably is differential shrinkage, but just make sure. Look carefully at the isotropic shrinkage and compare it to volumetric shrinkage. The trends should be very similar. Modify the appropriate deflection plot and use Volumetric shrinkage as the data set. This should help you easily see the correlation between the shrinkages and warpage. It is difficult to know if the shrinkage around the gate is a problem from what I read, but comparing the results as mentioned should help. Generally I ensure the gate is freezing under pressure, i.e. the gate freezes before pressure is released. I have a feeling your biggest problem is packing at a high enough pressure to keep the shrinkage down but maintaining the clamp tonnage withing limit.
As mentioned in other messages, reduce pressure over time to make the shrinkage more uniform through the part. This only works well if the shrinkage at the end of fill is acceptable, and the wall thickness variation in the part is not significant.
Good luck,
Jay Shoemaker
Good luck,
Jay Shoemaker
Options
- Highlight
- Email to a Friend
08-27-2009 01:22 AM in reply to:
nitinhadpe
I think that the first thing to find the right packing profile is search when the gate freeze (time).
When gate freeze, no more material/pressure goes inside part and this is the important thing.
So when you know that part fill in 1.5s and gate freeze at 12s, you have only 10,5s for pack the part.
If you analyze time to reach ejection temperature, you know what time gate freeze, and this time is counted after filling time.
So:
fill time=1.5s gate freeze=12s
1.5-12 = 10.5s
Packing time = 10.5s
Relative to packing pressure, i usually use maximum injection pressure (constant profile), or more or less 80% of packing pressure.
It depends of the parts.
João Esteves
So:
1.5-12 = 10.5s
João Esteves
Options
- Highlight
- Email to a Friend
09-17-2009 02:28 AM in reply to:
nitinhadpe
First of all,
I thank you all for sharing your valuable time and views and sorry for my late reply.
It will be really helpul to me..
Nitin Hadpe
Nitin Hadpe
Nitin Hadpe
Nitin Hadpe
Options
- Highlight
- Email to a Friend
01-29-2010 09:29 PM in reply to:
nitinhadpe
Steps are as follows
1. V/p switch over time (use text screen output i.e log) - T1
2. Gate freezing time (use frozen layer fraction plot )- T2
3. Take a plot of pressure at node (at end of fill node) -note down time at peak pressure and when pressure becomes zero( T3 & T4)
4. Then take average of T3 & T4 = T5
5. Constant pressure time T6= T5-T1
6. Decay time - T7 = T2-T5
Set packing profile - 0 80%,T6 80%,T7 0%. RUN ANALYSIS.
THEN ADJUST PROFILES AS REQUIRED ON BASIS OF REQUIRED LEVEL OF UNIFORMITY IN
VOLUMETRIC SHRIANKGE PLOT
At gate area: If volumetric shrinkage is high? If volumetric shrinkage is low?
If volumetric shrinkage is high at gate, increase decay time (T7).
If volumetric shrinkage is low at gate, decrease decay time (T7).
At mid region:If volumetric shrinkage is high? If volumetric shrinkage is low?
If volumetric shrinkage is high at mid, make one more stepped profile after constant time and change time and rate of decay and do trails
At End region:If volumetric shrinkage is high? If volumetric shrinkage is low
If volumetric shrinkage is high at end of fill , increase packing pressure , i.e set packing pressure > 80% , 90%, 100%, 110%, 120%.
and also increase constant pressure time (T6).
If volumetric shrinkage is low at end of fill ,decrease packing pressure , i.e set packing pressure <80 %, 60%,40%
and also decrease constant pressure time (T6).
Madhukeshwar Talwar
Options
- Highlight
- Email to a Friend
03-04-2010 10:50 PM in reply to:
nitinhadpe
I don't know to many about parametrization of a mould injection, but i would like to know how can i choose the value of (depending of what) packing pressure?
I am making analisys with a packing vs time profile for a bib flat part with 2.5 mm wall thickness.
Thank you,
Thank you,
