• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    Board Manager
    Project Scandium once again available on Autodesk Labs
    408 Views, 2 Replies
    02-21-2013 10:53 AM
    The Project Scandium technology preview has returned:
    http://labs.autodesk.com/utilities/scandium
    It is compatible with Autodesk Simulation Moldflow 2013. I have made the 64-bit download available on the Autodesk Labs site. I have the 32-bit version if anyone wants it, but my guess is that most early adopters are using 64-bit.
    Capabilities in this technology preview beyond the commercial release:
    • New Thermoplastics Bi-injection Molding process for Midplane analysis technology
    • New injection-compression (video) and pure compression molding (video) process simulation capabilities for 3D analysis technology
    • New mechanical property prediction for long fiber-filled thermoplastics composites.
    • New Buckling analysis option for 3D analysis technology
    • Various Solver enhancements address accuracy and speed.
        1. New Crystallization analysis result displays final average crystal size distribution
        2. Midplane and Dual Domain Warp solver accounts for viscoelastic mechanical properties of thermoplastics
        3. Improved time to solution for Microcellular Injection Molding analyze
        4. Cartridge heater enhancements for 3D elements
        5. Wall slip option added to 3D flow solver parameters
        6. 3D Gas-assisted Injection Molding analysis supports multiple gas cylinders
        7. New results produced by the 3D flow solver
        8. Large deflection stress analysis parameters enabled for 3D Microchip Encapsulation analysis
        9. New 3D result mapping method improves time to solution
    • FBX export capability increases visualization options among Autodesk products.
    The Simulus technology preview requries Autodesk Simulation Moldflow Synergy and Insight 2013 licenses, and the technology preview will expire on August 17 2013.
    We are looking forward to your feedback.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Please use plain text.
    dg
    New Member
    Re: Project Scandium once again available on Autodesk Labs
    03-06-2013 06:00 AM in reply to: scott.sheppard
    I'm participating in project scandium and noticed a problem. I'm trying to do overmolding for thermoplastic compression molding and can't seem to get the inserts to work. My regular thermoplastic injection molding version of moldflow allows for inserts, but not the new scandium. I can' put them in and select their properties correctly, but the analysis won't run. Any help would be greatly appreciated.
    Thank you,
    D.York
    Board Manager
    raalteh
    03-07-2013 08:28 AM in reply to: dg
    I'm happy to see you are using the compression molding code. We are very excited about this.
    Correct, at compression molding currently does not support insert or two shot overmolding. However we are aware of this and it's being considered for the future.
    Best regards,
    Hanno
    Hanno van Raalte,
    Product Manage for Autodesk Simulation Moldflow products
