Plastic Flow Animation
Is there any way you can fine tune the step amount when running a Plastic Flow animation?
Moldflow  Advisor 2010
nordhb
if you by fine tune steps means change number of frames, you can change number of animation frames.
After selected the result Plastic flow
Right-click and select Properties...
tab Animation
Change number of frames.
or set the Value range in time
This specifies the number of frames to be generated for the animation.
Hope this solves your issue.
Berndt
Berndt Nordh
That worked great. Thanks for your help. Tim Davis Vector Tool & Engineering When forwarding, use "BCC" and press "Send" only AFTER you have deleted all extraneous email addresses from this email. It's the smart way to share. If you forward this email, please delete the forwarding history, which includes my email address! It's a courtesy to me and others who may not wish their email addresses sent all over the world, and helps prevent Spammers from mining addresses and viruses from being propagated. This email and any files transmitted with it are confidential and intended solely for the Recipient. If you are not the named addressee you should not disseminate, distribute, copy or alter this email. Any views or opinions presented in this email are solely those of the author and might not represent those of Peterson Manufacturing and subsidiaries (Maxi-Seal Harness, Mission Plastics North/Arkansas, Transworld, Vector Tool) . Warning: Although Peterson Manufacturing and subsidiaries (Maxi-Seal Harness, Mission Plastics North/Arkansas, Transworld, Vector Tool) has taken reasonable precautions to ensure no viruses are present in this email, the company cannot accept responsibility for any loss or damage arising from the use of this email or attachments.
