Autodesk Simulation Moldflow Adviser
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Import IGES from Solidworks (To make refrigerat ion chanels)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How can I impor IGES files to use in refrigerations channels?
AMA 2011
SOLIDWORKS 2011
tx
Re: Import IGES from Solidworks (To make refrigerat ion chanels)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
in the cad system extract center lines of cooling circuits as lines/curves.
Trim lines in the break points, where circuit changes direction.
Export the center lines of cooling circuits as iges curves from the cad system.
In Autodesk Moldflow Adviser, go to Geometry.
Click Cooling System, down-arrow
Import Channels
file type : *.igs
When importing an *.igs or *.iges file, the process will import each segment of the cooling system as a centre (axis) line,
and apply default cooling channel dimensions.
Baffles and bubblers are converted into cooling channels, and these elements will need to either be defined or added manually, after import.
Berndt
Berndt Nordh
Moldflow Support Specialist
Product Support
