• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    How to renumber the element and node number in Synergy 2013
    264 Views, 6 Replies
    07-05-2012 01:03 AM
    Does anyone know how to renumber the element and node number in Synergy 2013 ?
    Up to Synergy 2012, "Global Merge" function did it but it seems that in Synergy 2013 only the node number can be done.
    I want to know why the specification was changed in Synergy 2013, or does anyone know the another solution?
    (Old reference: http://forums.autodesk.com/t5/Autodesk-Simulation-Moldflow/Solver-Warning-201434/m-p/3335727/highlig...)
    Best Regards,
    Shige
    Please use plain text.
    Valued Contributor
    PascalGosset
    Re: How to renumber the element and node number in Synergy 2013
    07-05-2012 06:37 AM in reply to: segafredozanetti
    This trouble occured several years ago.
    But did you installed the Service Pack 1 ?
    http://forums.autodesk.com/t5/Autodesk-Simulation-Moldflow/Moldflow-2013-Service-Packs-and-Language-...
    "Maybe Moldflow does not work properly, but the real world neither."
    Employee
    07-06-2012 02:58 AM in reply to: segafredozanetti
    In 2013, you can do a global merge, and set a negative number. This will do only a renumbering of nodes and elements, and not try to merge anything.This a new feature.
    I tested on a simple midplane model, and it renumbered nodes and elements.
    07-08-2012 04:05 PM in reply to: yannick.moret
    Hi, yannick-san
    Thank you for the information.
    According to the above information I tried it with mid, dd, 3d respectively but all did not work for element numbers.
    I used Synergy 2013 FCS. Which version of Synergy have you tried?  "SP1"?
    Employee
    07-09-2012 12:06 AM in reply to: segafredozanetti
    I used SP1 but as far as I know, we didn't made any changes there.
    I created a simple midplane plate in synergy, meshed it, remove elements T1 to T3, used the global merge with a negative value in the merge tolerance field, and checked if I can find elements T1, T2 T3.
    If you still have issues, please raise it through support.
    07-09-2012 03:05 AM in reply to: segafredozanetti
    Hi, Yannick-san
    Thank you for your quick response and information of process.
    In accordance with your process, I could renumber the element number, too.
    Thank you.
    But it seems that we need to delete any element to do it.
    Before Synergy 2012, deleting any element was NOT needed.
    Without deleting element, is there any other way to renumber the element number?
    If not, we hope to fix in the next version up.
    Best Regards,
    07-25-2012 11:38 PM in reply to: segafredozanetti
    I was misunderstanding.
    By global merging with negative value, I could renumber it.
    Thanks.
